BusdriverExplorer IIJul 20, 2021Brake WireThinking about running new wire for my Trailer Brakes , just not sure what size wire I should use.? The wire the manufacturer used is very thin.
time2rollNomadJul 21, 202150' of marine tinned duplex wire is $55 #10, $36 #12, $30 #14.I would probably go #14 for 1 axles, #12 for 2 axels, #10 for 3 axels.https://www.genuinedealz.com/collections/flat-duplex-dc-marine-wireI have seen some go with a bus and run separate wires to each wheel.For truly superior braking skip right on up to hydraulic disks ;)
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related ContentFleetwood Angler wiring2005 SixPac D850 WiringBad tail light wiringAdding power outlets in slide with no wiringbrake wiring
