Atwood 10 gal elec/gas water heater. Electric not working, gas fine. The switch inside coach, to turn on electric, ??? It always gave me no trouble. I watched the voltage meter in the wall outlet and ...
Whenever I read that work has just been done on a unit and now it doesn't work, I suspect that the unit hasn't been reconnected correctly.
One of the first things to check after making sure it is reconnected correctly is the electric heating element. Did you fill the heater with water before turning it on?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
