Atwood 10 gal elec/gas water heater. Electric not working, gas fine. The switch inside coach, to turn on electric, ??? It always gave me no trouble. I watched the voltage meter in the wall outlet and ...
Thank you all. Breaker good, switch good, replaced worn looking ECO and T-stat and was headed to check and replace heating element. Needed to pull it completely out and my heat exchange hoses were full and thought there might be a shut off, but no luck. Going to clamp hoses shut or put plugs in the ends. Last time I pulled this unit out, did not have a drop of antifreeze come out.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
