ScottG
Mar 25, 2018Nomad
Yes! Look at the caps where the wires connections are. Often when the cap has failed, there is physical damage to it. It may even puke its guts out!
Here is a link to what some types look like when they let go or are about to.
If the end that has the connections isn't flat, it's probably bad.
Some also have a little rubber plug in a hole. That's a vent and stuff will blow out of it at death.
If you could post a pic, we could probably tell you if they've failed.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
