laknox
Sep 17, 2018Nomad
Broken solar panel
Long story, but I got a 100w HQST solar panel kit. Panel got dropped and shattered the glass before I could set it up and I can't get it replaced. It's tempered glass, so didn't fall out of the fram...
bpounds wrote:
As I recall from your other threads, you are planning to use these panels in a portable setup. Not mounted to the roof, and not permanently out in the weather.
Why not just give the packing tape idea a shot, as time2roll suggested? Waterproof shouldn't be an issue if you set it out manually when needed, and yellowing will take a long time coming if it spends most of its time packed away.
Or maybe your portable plans have changed? Even if so, might be the best way to salvage this one for near zero cost.
