isellsunshine
Oct 07, 2014Explorer
Ozlander wrote:
No way would your frig use $40 worth of propane a month. Either you have a leak or the furnace is running.
You're probably right.
It's a little hard to pin point exactly as we are in Arizona 1/2 the year where we don't run furnace at all, and then we were in Minnesota where we do. Our propane usage went up, so it's hard to tell how much of it was furnace and how much running fridge on it round the clock.
How much propane does running fridge use in a month do you think? I have standard RV fridge/freezer combo and run it on the middle setting.
Would be good info to have, to determine whether fixing the fridge board is worth doing.
It may not make sense dollar wise to fix it.
Susan
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
