RAB's avatar
RAB
bubbles coming out of gas line
When I attached a hose to my fuel rail to remove some gasoline from the tank (by turning on the in-tank fuel pump), gas comes out in a strong clear stream. When I turn off the pump, gas continues to come out by syphon action (although flow is much less of course) but with a steady stream of bubbles. Where are they coming from? The car is a 1995 Geo Tracker with the 4 cyl. 16 valve engine. No fuel leaks and everything in perfect working order.
  • If the fuel pressure regulator leaks (spring pressure suppose to keep it closed)that could be where air is entering. Will repeat with return line pinched closed and see.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
