BFL13's avatar
BFL13
Explorer II
Nov 04, 2014
Buck Gizmo Test Results
This test was to see how much the amps went up at the output of the buck converter compared with the input amps. This is the gizmo again:
http://www.ebay.com/itm/DC-DC-15A-Converter-Buck-Adjustable-4-32V-12V-to-1-2-32V-3-3V-5V-24V-Step-Down/281206555382?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D25217%26meid%3D8539ba1eede94f48b9c4da74610ac108%26pid%3D100011%26prg%3D10629%26rk%3D5%26rkt%3D10%26sd%3D351129151726&tfrom=351129151726&tpos=unknow&ttype=price&talgo=origal
So first I attached four pigtail thin wires to the terminals set screw type and then attached fatter wires to those and got all set up.
I put my two, 2a float chargers in series and tested the output at the "working" clamps at 27.0v
No load bench test of adjustable voltage CV screw pot. With 27v in, and meter on output, set it to 14.8v The little screw turns many times and you can set voltage exactly all the way through its range. In this case I stopped at 26v output in case I would fry something hitting the input voltage, no idea, but I had not even started the test yet so that would be annoying to fry it now. ok
Next test is with no input, connect to battery bank. The input voltage was the same as the battery voltage on the output, 13.82v, then with converter off, voltage down, 12.81
So it just passed through the voltage going that way from out to in across the circuit board.
So now the biggie, with battery connected 12.8v, connected input 27v with ammeter in the pos input line showing amps bouncing around between 1.55ish to 1.75ish----------so what were the output amps????
The same!!! Rats, phooey. Ok , maybe the batts won't accept any more, try it with a load. On Trimetric without the buck converter on, got 12.3v and -20.3a. Turn on gizmo, 12.3v and -18.3 so 2a from gizmo. Tried a few more like that pretty much the same results
Maybe a slight hint of higher amps? Hard to tell with these small amounts and rough instruments but it sure didn't double the amps like I expected.
OK final desperate test using an actual 230w solar panel as input.
Dull day so panel de-rated already so ok for input to gizmo at
Voc 31.0 Isc 0.3a Batts now 12.8, no solar Tri shows -0.3 to -0.4 back and forth as normal with converter off. Add solar power to gizmo, amps on Tri now 000 to +0.1
So same as panel Isc for gizmo output or maybe a titch more , hard to say.
RATS!!!
So what went wrong? Should amps have been more at the output or not?
Thanks.
