BFL13's avatar
BFL13
Explorer II
Oct 12, 2014
Buck Your Solar with a Mex Gizmo?
Mex has a thread about equalizing with this sort of gizmo
http://www.amazon.com/DROK-Constant-Current-Converter-Regulated/dp/B00E8D7XYG
There are many of these on ebay with different specs, so that one might not be the right one, but for this idea assume there is a right one.
The idea would be to use one of these with a standard $15 PWM solar controller to buck its amps while keeping voltage to the battery under 15v.
Would it go before or after the controller? What settings would be used for adjustable voltage and current? Would you have to keep twiddling with the settings all day? Not too clear about how you get the amps to taper either. You guys are supposed to solve all that! :)
Background-- we know that an MPPT controller has a buck converter plus an MPPT feature. "MPPTs" go to PWM to do the Absorption Stage and Float Stage, but they will keep on bucking the amps after going PWM.
So I am thinking you could use one of these little buck converter gizmos somehow to work with your basic PWM controller and get more amps to the limit of the controller's amps rating-- higher amps than the "12v" panel's Isc which is now the max amps.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
