jrnymn7 wrote:
When the full batts wouldn't accept anymore amps, what load did you apply?
20amps worth of lights and fans (mentioned above where that went to 18 showing a 2a input.
the gizmo output was set at 14.8v but the voltage at the output terminals was same as battery when all going of course. The output voltage was way less than the input voltage. Input amps measured correctly as 2a ( two 2a chargers in series) So I suppose input watts was 27 x 2 = 54w If output watts was also 54 and voltage 13 (say) then I should have seen 4 amps out instead of 2. I thought. Nope.
