MEXICOWANDERER
Oct 12, 2014Explorer
I don't "think" this will start a fight between the gizmo and the controller. The gizmo would go between the controller and batteries.
I much prefer the 600 watt version of this type of DC to DC booster. It is much more robust.
A booster INCREASES voltage. If you wanted to FLOAT control a PWM controller, use a BUCK gizmo, but be aware of the Delta T limitation. I would choose a silicon rectifier and drop voltage .7 volts or a shottky and drop voltage .4 volts.
