BFL13
Oct 14, 2014Explorer II
JiminDenver wrote:
Hmmm
220w mono panel hit 40v+ on a cold winter day, even after it settled down it stayed at 38v so gizmo would die.
There should be a way to reduce that voltage before it hits the gizmo. Maybe with one of Mex's light bulbs or whatever. We need a gizmo for the gizmo.
To equalize with it, I gather you would also need an adjustable amps output to set at 5 amps per batt, then twiddle the voltage output upwards to maintain that constant amps. This gizmo only has the one adjustment screw for voltage it seems.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
