BFL13
Oct 17, 2014Explorer II
JiminDenver wrote:
I don't think the MPPT is going to get you more amps out of the buck converter, they are already there. The MPPT just decides what is the best way to charge the battery, test the array, etc. YOU become the MPPT.
I thought it was for solar panels (the gizmo buck might have some other input in different applications) where it "hunted" to "lock on" the MPP of the panel's IV curve. So when "on" it should get you a tad more in amperage?
Goes back to that good question earlier. You can select an output voltage and you get what you get for input. Amps are whatever happens. With solar panel input, are you ( with the MPPT) not selecting the input somewhat too in hopes of getting the most amps?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
