BFL13's avatar
BFL13
Explorer II
Jul 10, 2014
Bucking and MPPT?
Question here is whether I saw where the effect of MPPT was seen or not---was the amount of change about right?
Situation was controller (Eco-Worthy 20amper) was showing 14.4v (as set by me for Float), low amps with batts near full showing Float on its readout, when I added a bunch of load for a test I wanted to run on a different topic.
I happened to be watching the readout when it went from-
13.0v, 12.4a, 161w, Float, to-
13.0v, 14.31a, 185w, Bulk
The first is where in Float it is bucking to support the load but not in MPPT and the second is when it went into MPPT.
Is the rise in amps from 12.4 to 14.31 at that moment "about right" for MPPT effect? There was not time for the voltage to fall off that 13.0 reading to account for the rise in amps although it was slowly "passing through 13" at the time of course.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
