MEXICOWANDERER
May 02, 2015Explorer
Senor Pianotuna, I am going to build you a 1-3/4" X 1-1/2" circuit board. When I go north I will send it via UPS to Saskatchewan. You need to PM me your mail and package address.
The gas tube discharge device is rated at 5000 amps. 180 volts peak-to-peak on the Transient Voltage Suppressors, and 250 volts on the multiple MOVs.
The board will have nylon standoffs on all 4 corners. A small sheet metal screw passes through the circuit board, through the hollow standoff, then through the rear wall of your AC breaker box.
Three wires. 10" in length. Black, white, and green. Self-explanatory.
And, oh, this is a gift. It will be declared as such with a value of eighteen cents Canadian. Ottawa is awash in Loonies. They need none from me...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
