wnjj
Aug 12, 2015Explorer II
First you need to figure out if the compressor is even running or just the fan. Does your thermostat have a fan switch with ON and AUTO? If so, turn it to ON before turning the mode to cool. If nothing changes (sound wise) when you turn on the cooling the compressor isn't running. If the compressor isn't running it may be a loose wire or bad thermostat. There are separate wires for fan and cooling between the thermostat and AC.
Honestly, leaking coolant seems least likely to me.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
