dave17352
Aug 12, 2015Explorer II
If you are running off the generator make sure you have enough voltage when the compressor kicks on and runs. It should be easy to hear the compressor run. I was running off a extension cord on a 15 amp circuit and my AC was not working correctly. Not getting very cool and the compressor kept kicking in and out. I checked the voltage and I was only getting around 105 volts when compressor was on. I found a 20 amp circuit and the problem was solved as I was at about 116 volts when the compressor was running. Perhaps you have a generator problem. JMHO
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
