DrewE
Feb 25, 2015Explorer III
If that's unfinished plywood in the compartment, you could glues a 1/2" or whatever backer plate (of plywood, normal wood, or whatever) to the 1/4" plywood and just use normal wood screws into that. Any decent wood glue or epoxy over a reasonably large area will support an enormous amount of weight (assuming proper application); the goal is to make a thicker thing to mount the box onto. I see westend said pretty much the same thing, now that I reread things....
Molly bolts are another option kind of similar to well nuts, but they won't remove themselves...nor can anybody else reasonably remove them, for that matter. You do need sufficient room in back of the panel for them to work.
I don't know why you'd ever have to remove the breaker box to inspect or work on things inside it. Everything is clearly in the open once the cover is removed.
