Almot
Feb 26, 2015Explorer III
myredracer wrote:
Is the wall paneling/plywood really 1/4"? I thought 1/8" is what is typically used. You might be able to pull the plywood off the forward wall of the pass-through if it's just stapled in place. I removed that piece in a previous TT and it peeled off in seconds. That could give you wiring access and a way to mount a backer board behind the paneling.
Yes, I think it's 1/4" plywood.
Not sure how easy would be pulling it off the wall. Probably doable. Plywood sheets in the pass-through storage are stapled to studs and covered with plastic wallpaper. Where 2 sheets of ply join each other on the wall, the wallpaper is overlapping on the seam. In the bedroom there is also wooden trim/angle where interior walls meet each other in the corners, this trim is also covered with plastic wallpaper.
As I recall, PL40 or similar adhesive was what people used to glue shelf supports to wallpaper in closets.
