RoyB
Jan 15, 2017Explorer III
This is a neat little diagram discussing the Antenna WALL PLATE function...
Google image
I ran into a TV PLATE that had two type F connectors on it. Think it was installed for SAt TV or some other unknown reason. This required to have a jumper type F cable installed between the two connectors to use the CABLE TV INPUT outside connector...
Google images
If the trailer has been previously owned there is sometimes no idea what has been modified by the previous owner haha...
Best bet is run the cable TV connection through the window and connect directly to your TV SET for a quick test to eliminate things...
Roy Ken
Google image
Google images
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
