Old-Biscuit
Jan 15, 2017Explorer III
fulltimedaniel wrote:dougrainer wrote:
1. The Booster must be OFF to get Park supply to the TV
2. You MUST have the TV set to CABLE for the park supply.
3. Use a splice and run the Park cable thru a window direct to the TV. IF you get the channels you know the Cable connections at the Booster are miswired.
4. There are usually 3 coax cables at the back of the booster and will be labeled as such on the plastic wall plate
1. Antenna IN---it works and is correct because you get antenna
2. CABLE IN
3. Out to 2nd TV
5. Swap the Out to 2nd TV and the Cable in coax at the booster. Then if the system works you have found your problem. If NOT, then there is a problem with the coax cable from the outside input to the booster. Doug
Numbers 1.2 and 4 have been done already as my first step and looked at I will try the direct cable to the tv.
Thanks for the suggestions
I am guessing the park makes you pay extra for the cable but doesnt come out and say so.
thanks again
With booster OFF, TV input set to cable DID you do a 'auto scan' for the cable channels???
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
