rk911 wrote:
MetalGator wrote:
We just purchased a new motorhome. We are staying at a RV park that includes cable. I can scan for over the air TV stations and everything works fine. However, when I put the TV on "cable" mode and scan, I only get a handful of stations and they are over the air stations and no cable channels. On my previous travel trailer, I had to turn off the TV antenna pre-amp before I could scan for cable channels. On this motorhome, I don't see a way to disable the TV antenna. I have the coax connected outside. Any ideas? I do have a HDMI switch box which will connect the Blueray player (and I connected a Ruko device) but I can't seem to figure out how to get cable TV to work. This is a problem since college football starts tomorrow!! :)
Burch
Burch, try turning OFF the over-the-air TV antenna amplifer and then re-scan for cable channels. also be sure that the INPUT on the TV is on cable (you implied you've done this but just making sure).
I don't see anyway to turn off the antenna amplifier. On my travel trailer, there was a switch in a cabinet that would turn off the amp. I had to turn it off or the cable scan wouldn't work. I don't see any type of switch for this antenna.
Burch
