1L243 wrote:
Slapped back to reality not only buy the thoughtful comments here but found the price of a 3000 watt pure sine inverter with smart charger and built in transfer switch ridiculous.
I will forget the idea of electric heat but would like to be able to power Tv's, Satellite, USB charger, Furnace if needed and a coffee maker once a day plus a small microwave for 10 minutes a day.
I will research a 1500 to 2000 watt pure sine inverter with smart charger and built in transfer switch. Is a all in one inverter the way to go or would going with separate units be more practical for purpose of replacement and cost?
Inverter with built in smart charging is a bit useless if you are planning all solar charging..
The smart charging built in to inverters is from 120V AC shore power, not compatible with DC from solar panels..
Solar panels would need their own "smart" charging controller, making paying the extra premium price for a "all in one" inverter/converter a bit of waste of your money.
Built in transfer switch is not really needed if you are planning to be 100% off grid and zero gen use..
So, you could just buy an inverter that meets you max wattage needs without the transfer switch or charger and just plug your shore cord into the inverter.. Saves a ton of money for batteries and solar..
Personally, put some money upfront in a good brand inverter and that may not be the cheap no name "pure sine wave" inverters..
My favorite inverter is made by Tripplite, I am using a PV1250FC for my home fridge conversion.. It IS a MSW but it is a big heavy duty industrial inverter designed to handle high start up surges from inductive loads. 1250W continuous, can handle surge up to 2500W for up to 10 minutes.. Not going to find any other inverter that has such a long surge capacity, most are microseconds..
Looks like this..
Weighs a whopping 22 lbs!
Currently $288 for that beast..
HEREIf you feel you must have 2,000W then a PV2000FC would be what you are looking for..
If you MUST have 2000W AND Charging AND transfer switch, then Tripplite APS2012 is what you are looking for, it is 2,000W with ATS and charger built in and is a hardwired unit..
Currently it is going for $730
HEREYes, it is also MSW, Microwave oven will work on MSW, might be a bit reduced on power (take a bit more time), some items like electric blankets/heating pads with all electronic controls may not work with MSW but pretty much everything else will work.
USB chargers, do yourself a huge favor, just buy a cig lighter plug in USB charger. That is silly and a huge waste of battery power to run a USB charger from an inverter.. Put a couple of cig power ports in your RV and use a couple of the 12V to USB chargers, they work very well and will use a lot less battery in the process.
For say a laptop PC, do the same, you can buy generic 12V to laptop power supplies, they use a changeable plug that sets the output voltage and amperage to your laptop..
For coffee maker, lots of non electric ways of making coffee, or I would recommend firing up the genny for that if you must have electric brewed coffee.. Electric coffee makers are the same issue as trying to use battery for heating.. They use a huge amount of wattage and to be able to use only battery power will require more battery and more solar..
Personally, if you skipped the microwave and coffee maker from battery usage you could get along with a small inverter for TV and sat equipment.. 300W-400W inverter should handle most LCD TVs up to 60" plus the sat receiver.. Smaller inverters have a much lower no load draw and loading them to half capacity will net you more battery efficiency than the way you are planning..
Conservation is king, oversizing the inverter for the loads will result in more battery usage..
Some folks actually use two inverters, one small one for TV/sat and one larger one for heavy loads like microwave.. Turn off the inverter when not needed and turn on when needed.
