TEO wrote:
After a year of problems and after he employed a law firm, Lazy Days was able to solve the problem. Although he lost many months of camping during the year, it is now working flawlessly. The electronic technician solved the problem by using relays in the system. A lot of the problems were really stupid and should not have occurred. Thanks to all for your input.
True related story:
I have a Remco Lube Pump on my towed. Well the original pump started "Stuttering"... (You could actually hear the motor stutter and in demonstrating for the repair guy I hooked it direct to the car's battery so I know what I'm about to type was NOT the problem) New motor worked great. for a while, then started blowing the fuse.
So I tried a circuit breaker, and promptly blew the controller
So I fixed the blown trace on the controller and added a relay.
Now that fixed the blown fuse but added more issues.. I Finally fixed those too.
But I finally found the cause of the fuse blowing.. IDIOT INSTALLER ERROR
Ran the hot (and sensor) wires under a frame member if I run up on a parking stop (and it at just the right height) it scrapes the wires bare.
Wires are now re-routed.. Good thing I'm trained in this kind of stuff. But when I get back to MI I'm gonna have words with that shop.
