SidecarFlip
Aug 29, 2017Explorer III
It's dark and raining here too (I'm in Michigan like you are....)
Did you per chance have your fridge set on automatic instead of manual propane only? It could have switched to 12 volt and the 12 volt heater in the boiler will quickly wipe out your batteries...
Keep in mind that just because it is running propane, it's still pulling 12 volt power, not much, about 2/10th of an amp but if you have fans in the back cavity (like I do), the consumption jumps up to 2 amps. A fridge will pull down to around 11 volts before the circuit board cuts it off.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
