GaryS1953
Aug 30, 2017Nomad
MEXICOWANDERER wrote:Can you recommend such a charger? I've only got a small trickle charger so I'm charging it with the converter currently. I just checked this morning and the batteries were only up to 10 volts.
I'll stick with the battery issue...
Those batteries need to be recharged "hard" in order for them to have any chance at all to recover. A 40 amp electronic charger to full automatic charge then press the equalize button half a dozen times may do it. The electrolyte in all cells has to bubble vigorously for a couple of hours. Take the voltage level to 16.0 But disconnect the battery before you do this. A high quality hydrometer would tell you immediately where you were at in this process.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
