bdpreece
May 26, 2019Explorer II
CA Traveler wrote:jentrxm wrote:Normal but not desirable unless you want to unplug/plug all the time.
Thanks everyone! Glad to know it's normal and not some crazy wiring issue.
One simple solution is a relay in the Jeep charge line that is activated by the ignition. Don't let the same tech near your equipment.
An even simpler solution is to put a diode in the line. Current will then only flow one direction.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
