dougrainer
Jul 22, 2020Nomad
1. MOST tank heaters are 12 volt and could NEVER heat the contents hot enough to notice.
2. MOST Tank heaters have a built in Tstat in the connection at the tank heater, so they would not operate above 40 degrees ambient temp
3. STEAMING Water from the Black Tank?????????? I would check your diet, not worry about heat from the RV systems:B
4. Your Water Heater regardless of proximity to ANYTHING cannot transmit any excess heat, especially to a Black tank or Gray tank.
5. Yes, you are going to have to climb underneath to determine what is happening.
6. Now, it IS possible you have a HOT Water line connected to the toilet instead of a COLD water line. THAT is easy to verify. Run the toilet flush and put your hand on the Water Intake line behind the toilet. IF it is HOT/VERY warm, that is how you are getting hot water to the toilet, but still, enough to cause the Tank to "steam"? NO WAY. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 11, 2026
