Ramblin__Ralph's avatar
Oct 31, 2021
Camping 3 months with single 100Ah Lithium
Before I started ramblin' this summer, I replaced my two lead acid batteries with a single 100 Ah lithium. I also added a second solar panel to go from 125w to 225w.
I was on the road almost five months, and three of those were dry camping every night. Usually at the end of the day my battery was down to around 90%. The next day it was quickly up to 100%. On Labor Day weekend I camped in a shady spot for four days. At the end of that my battery was down to a little less than 70%. It took a couple of days to get back to 100.
I don't have any high power devices on my camper. My furnace draws the most, at 4 to 5 amps. I only ran it for about 15 minutes in the morning, when needed. All my lights are LED. My fridge was running on propane the whole time. I installed a DC-DC converter before I left home, but never used it.
FYI, my setup is a single AmpereTime 100Ah 12v LiFePo4 ($540 last Jan when bought and $400 now, on Amazon), 225w of solar panels, Victron MPPT 75/15 solar controller and battery temperature/voltage sensor, and an eBay purchased battery monitor that records amp hours. Turned out the battery doesn't have low temperature charge protection, but the Victron solar controller takes care of that.
I'm very happy with my installation and doubt now that I'll ever need other than my solar charging. Now I don't have to remember to check battery water and strain my old body to lift a battery. :)
  • Good report, although I think the title is misleading.
    You camped 3 months on solar power, where battery was just a storage and it did not matter if that was lithium, or lead-acid.
  • I recently bought a 200 amp Lithium battery and will probably install it and a new solar controller in the next couple of weeks…need SIL to assist me lifting out old batteries…buried between trailer tongue rails. I differ in Ralph’s electrical usage only due to my desire to watch local news on TV. I’m planning on only solar for recharging. If 3 100 watt panels aren’t enough, I’ll add.
  • Sounds like it worked very well for you. Congrats.
  • Did you use only solar panels to recharge the battery or is Truck also able to charge the battery? I know very little about solar panels as of now. Enjoyed and saved many of your photos over the years. Thanks
  • I need better metering in my TC. Far as I can tell, I get about three hours usable battery life with the laptop on and the dinette table led on. I have basically the same amount of solar and 2 group 31 AGM 105 AH batteries. I plan to setup up about 600 watts solar and 400 AH battery. I think that's what it'll take to supply my power demand, especially at night in cold temperatures. I refuse to be cold at night, especially in the bathroom at 3 in the morning or whenever. Those walls are COLD.
  • Good to hear that the Ampere battery has served you well.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 20, 2025
