BFL13
Jan 26, 2017Explorer II
pnichols wrote:
BF - the last time I checked those Honda 3000is were expensive (but quiet).
I shouldn't bring up this taboo subject but here goes ... couldn't you have just idled your truck engine to good-enough charge your batteries? Unless it's a diesel, it probably idles as quiet as the big Honda, anyway.
We got this gen in early 2003, so 14 years still going strong makes it come out better in $/yr :)
No, the noise is ok, and no issues with long time idle for the gasser, but the amps are not ok. I have tested for that using fat jumpers and also with inverter on truck battery with inverter running chargers. Best I got was about 50 amps. As seen above, I need more like 150 amps to do a 50-90 in two hours in this situation.
You might get away with running the truck outside of park gen hours though.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
