Almot
Nov 01, 2014Explorer III
RKW - no.
Even most sophisticated solar controllers don't monitor ALL the input sources to battery. I've only heard of one "exception", sort of - Midnite Solar Kid 30A MPPT. They offer an optional battery monitoring add-on, but I think there are better 30A MPPT controllers out there (and there are also cheaper MPPT, if budget is your primary concern, and then of course there are cheaper yet PWM).
However, I've been lucky in not needing a battery monitor when off-grid. My controller display tells battery voltage, solar amps and amp-hours or watt-hours IN. It also tells the battery charge status and the history of charging by the end of the day, i.e. was Absorb or Float ever reached and for how long. Since it gets to Float by noon on most days, and very close to Float on those days when it doesn't, I don't care to monitor amp-hours OUT. I don't have other sources IN, and neither feel any need.
If you follow links suggested by Don Pianotuna, and considering your location, you should be able to get enough solar amp-hours without any other input sources. The only times when you will need a generator, will be when you run air conditioner, and that time can be reduced with 12V fans like FanTastic and others.
It looks like Xantrex have replaced Link 10 with Link Lite.
To me, Victron looks nicer than Xantrex or Trimetric. Single-battery version is $40 cheaper.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
