Ivylog
Feb 17, 2016Explorer III
1400/12V= 167amps X 0.05 hours (3/60= 0.05) equals 5.85 Amp/Hours at 100% efficiency. Inverter at 85% increases the 5.85 to 6.88 AH... BUT 196 amps from your two batteries will probably pull the voltage down to where the inverter shuts off. Anytime you use that many amps (even for 3 minutes) I'd crank the generator or boil water with your propane stove.
