3_tons
Nov 19, 2018Explorer III
Roadrunner, I believe you’ve identified your problem - ditch the 2 AWG cables because (at only 12v) they are causing a serious current bottleneck - I run my 11kbtu air cond off of two Costco sixers for 45 minutes to get to about 60% SOC using 0004 AWG... This inductive surge load is far greater than a 1500w MW and runs from a ProSine 2.0 with 4500w surge...Quite honestly and at my level BEST, I really can’t see how you are having a battery issue unless they are a bit older...My problems totally dissappered when I switched from 2 AWG to 0004 - with 2 AWG, I was actually STARVING the poor inverter...Been there and done that...This is also why I silver soldered the copper lugs...
3 tons
3 tons
