Naio
Jan 15, 2018Explorer II
Can I run this LED light off my PD 9280? Should I?
This is the light in question.
No, I am not looking at putting this giant thing on my rig! But I am stuck for now in a gloomy, dark part of the country, and I read online about people using vehicle light bars as SAD lights, and thought I might give it a try, see if it perks me up.
It's cheap, but shipped by Amazon, so I can return it if it's cr*p.
But I don't know much about LED lights and I know some of you know a lot!
These are the specs, if you don't want to scroll down:
Material: Anti-acid 6063 Aluminum Housing - Power: 500W
- Brightness: 50000LM
- Illumination Range: over 300M (984ft)
- Working Voltage: DC 10-60V(fits 12V, 24V vehicles)
- Number of Chips: 100pcs, 5W Cree 3030 LEDs
- Protection Rating: IP68
- Color Temperature: Nature White 6000K – 6500K
- Working Temperature: -40 to + 85 degrees Celsius
- Beam Angle: Spot (30 Degrees) and Flood (60 Degrees) Combo
- Lifespan: over 50,000 hours
- Dimention: 52*3.4*5.4 inch
Is it going to start the house on fire? Can I run it off the 12v port of my PD9280?
Thanks much for your opinions :)
