MrWizard
Jul 07, 2017Moderator
disconnect the leads coming from the panel to the controller
leave the battery output leads connected
set a digital multi meter on 200 DC volts
measure the voltage across those leads, should be 18 - 23 v
this is the VOC 'voltage open circuit' aka NO LOAD
now set the same meter DC amps, connect to the "10 amp" jack on the meter
now measure the amps
you reading the max short circuit amps
post the results here
a 2-3 amp reading is a 40w panel a 4-6 amp reading 80w or more
do this in high sun no shade on the panel
OR
you can unbolt the panel and read the specs on the label on the back of the panel
OR
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 08, 2026
