BFL13
Feb 01, 2014Explorer II
If the inverter is part of the RV fitting then be sure they did the wiring right so it is fat enough for its length so the battery voltage holds up over 11v when the inverter is running a 400w load.
You can test that by running four 100w lamps
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
