wa8yxm
Feb 01, 2014Explorer III
The dometic fridge, if on electric will require all the output of the inverter, If on propane it only eats direct from the battery, and the propane tank.. (Assumes it is an AC/Propane model)
The crock pot.. Wattage varies with make and model so turn it over and look at it, add 10% to the wattage and that will tell you the minimum size of inverter, 25 percent is safer. But odds are good it will work.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
