pianotuna
Feb 02, 2014Nomad III
Hi,
While you are driving you may use 450 watts. This will place a load of 45 amps on the alternator. The crock pot will eventually start to cycle, making it an intermittent load, which will give the alternator a rest.
The way to tell is to monitor the starter battery. If it stays above 12.9 you are ok. If it starts to drop lower and lower--then the inverter needs to be turned off. If the voltage stays at 13.2 you are laughing all the way to the bank.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
