dannytas
Jun 01, 2016Explorer
BillyW wrote:
Since the entire trailer can safely bounce down the highway on its tires, I'm sure you could get away with two jack stands on each side just fore/aft of the tires/axles.
Point well taken...I wrote in another post concerning a leveling system:
"I'm perplexed as why some would say that a trailer frame might not be able to support a leveling system or that it may flex. Think about where the trailer axles are located. The overhang alone would surely flex the frame under that train of thought. Of coarse when you travel, there is another point of contact,the hitch, but there's still the overhang in the rear. That said, if I were to mount a leveling system, I would mount the "feet" half way between the axle and the corner of the unit. To help to keep the frame from "flexing". I'm such a hypocrite."
I would just put the jack stands half way between the axle and the corner of the unit. Considering that this is just a temporary situation to do service to the rig. :D
