Almot's avatar
Almot
Explorer III
Jul 11, 2013
Can you pull 2*6 AWG through 3/4" conduit?
Need to pull a pair of AWG 6 cables from solar through the roof. When I look at some photos here, it looks like people are able to pull 2* AWG 4 through 3/4 conduit connectors. I don't have cables yet, will order when will know the exact length, and it will be AWG 6 welding cable. From what I know, AWG 4 is 0.4" OD including insulation. AWG 6 has 0.35-0.39" OD. It would be nice to use 3/4" connectors - those 1" are huge, I just have doubts. Are you guys squeezing cables to death, when routing them through the roof? Rubber insulation will give a little, alright, but is it good for cables to be pressed together, with 12-15 A current?
PS: In case if somebody is wondering what the heck I'm talking about :) , here is an old thread, see photo 8 from the bottom, it shows roof junction box. And there were other, can't find it now, also with 3/4" connectors. I know those connectors, they must be 3/4.
  • i guess i am confused why you need to run welding cables, is this for a 12 volt system or a 120 volt. 2 number 6 thhn style wires which is designed to go into conduit have a thinner coating on them will have no issue at all in a 3/4 pipe the welding cable is much thicker because of the exposure that it comes in contact with when it is used as a welding cable and also the 12 to 15 amps that you talk about is far below what a number 6 gauge wire is rated for which is somewhere around 60 amps or so
  • AWG 6 = .39" diam X 2 = .78". AVG 4 = .40" x 2 = .80". 3/4 conduit is .75" OUTSIDE diameter Makes for a tight squeeze. Any bends or elbows would be even worse. You would probably have to go to 1" conduit.
  • Just two #4 wires would leave quite a bit of space. They sell electrical lube for pulling wires through conduit.
  • According to the electrical code, you shouldn't. It won't breath well enough to keep the wires cool at max load which will defeat the use of those big 6awg wires.
  • Could you route the cables down the refrigerator roof vent??
    Or possibly along side the plumbing system vent??
    You should post the type and model of your RV.
    -Tom
