boogie_4wheel
Apr 17, 2014Explorer
skalashn wrote:
THE PROBLEM: I can start the engine after 15-20 pulls but only with choke closed. It runs choked but very unstable, surging and usually dying after a few minutes. As soon as I open the choke it stops immediately.
What am I missing?
Sounds like it is running lean. Needle set too low? Bring it up a notch, or space it with a #4 washer (assuming a #4 will fit). Or, turn the fuel mixture screw out as you slowly open the choke to see if you can wean it off the choke.
