fowlthing
Sep 08, 2021Explorer
Found the problem. And it took a voltage meter. The fuse in the front storage bin on the wire from the battery to the control module was only allowing 11 volts of juice. The fuse was lit up and showed continuity.
Also Lippert says the wire from the control panel should be connected directly to the battery not to the block near the battery.
I did that and put a new fuse in and it all works. 2 volts low and it would not work. Hope this helps someone else in the future.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
