lamopar
Mar 10, 2019Explorer
SoundGuy wrote:lamopar wrote:
My system looks a lot like the one on the video but it was supplied by an LP gas company. They made the lines that connect to my trailer output and connect to my grill. My connections look a lot like the connection on the gas bottle and the end of the factory Weber grill. One screws into my trailer connection and it ends after about 10'.
What you're saying makes no sense. 16.4 oz propane canisters have a 1"-20 threaded male fitting and is HIGH pressure. Any low pressure feed you may have on your trailer's curb side should be a quick disconnect fitting, if it's not then it's not low pressure. Any custom hose built to feed low pressure to a Weber Q on which the regulator has been removed should have a quick disconnect male nipple at the trailer end and a threaded fitting at the other than screws on to the Weber in place of it's regulator. Question - what make, model, year of trailer do you have and 2) a couple of pics of what you're talking about would help.
I am starting to wonder if the gas company made an error. The two hose connections look just like the top of a small gas bottle and what is the end of the original gas grill connection for the bottle. The end of the hose that connects to the trailer is the same and it just screws on. A quick connect would be much better with a shut off but that is what I have at the moment. I think I may need a different system.
Again, a major LP gas supplier put this together for me at the shop. It works pretty well but the flame is super low like it is going through two regulators but there are only hoses from the trailer to the connection at the grill and the regulator has been removed from the grill. I still have it in a bag with the connections.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
