CA_Traveler
Mar 10, 2019Explorer III
This is the high pressure adapter with a El (for hose routing considerations) and a shutoff valve. The top external tank port came with the adapter. The BBQ connector is the standard 1lb 1" propane bottle type.
Click For Full-Size Image.
12’ hoses and adapter for the standard BBQ regulator fitting are available. Propane stores can also make custom length hoses however I have a second 12' hose to use when needed.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
