- MEXICOWANDERERExplorerRube's drawings focused on mechanical shenannigans. When the OSHA horse came out it went viral within the rodeo world
- DrewEExplorer II
MrWizard wrote:
i remember a cartoon
OSHA's version of a safe horse ride
not sure that was one of Rube's
he sure could invent a complicated mouse trap
in fact i think the game of that name was invented because of his drawings
It's not a Rube Goldberg cartoon. Mr. Goldberg passed away in 1970, and OSHA was established in 1971. - GordonThreeExplorer
pianotuna wrote:
Hi BFL13,
Since I can run the 125 amps in the PF corrected Magnum with 924 watts of electric heaters, plus fridge, plus 50 watt heating pad from a Yamaha 3000 sIEB, I don't think there will be an issue with a Yamaha 2000 VA running only a 100 amp @ 12 volts PF corrected load.
I have not seen my Magnum go over 90 A running off a single Yamaha 2000, with the load limit set to 13a. Running two Yamaha, 3200 effective watts, 125 amp max charge rate is no problem.
That's a bummer folks are having trouble with the new hybrid 3012 - pianotunaNomad IIIHi BFL13,
Since I can run the 125 amps in the PF corrected Magnum with 924 watts of electric heaters, plus fridge, plus 50 watt heating pad from a Yamaha 3000 sIEB, I don't think there will be an issue with a Yamaha 2000 VA running only a 100 amp @ 12 volts PF corrected load.BFL13 wrote:
GordonThree, that is an interesting situation. The PM 100amper is PF corrected so it can run on a 15a circuit but I am not sure how much it actually draws in VA. It might well be too much for a 2000w generator. You can't set a 120v amp limit on it like you can with the charger portion of your inverter/charger either.
Not clear if that is what the trouble is when your inverter takes over from the gen when the 120v load gets a high surge. If so, then a lower amp charger might be necessary that can run from the 2000w or it will just pop the gen's breaker instead of running the charger as intended.
I am unclear as to how you get the generator to be on when one of these episodes happen. It is not like being on shore power. Anyway, there must be a way to get it all to work. - pianotunaNomad IIIHi Gordon,
At least one person is having trouble with a Magnum 3012 and load support. It is behaving differently and acting as if it were a non hybrid.GordonThree wrote:
The Magnum has a 125 amp charger built in. With one yammy I get about 85-90 amps at 13 amps input. Problem is, the Magnum's "brain" doesn't tolerate heavy loads cycling, even if the internal charger is shut off. It doesn't wait for the yammy to spool up when the dehum. compressor kicks in, instead it disconnects the generator and switches to battery.
The hybrid Magnum's brain works differently. Instead of disconnecting the generator, it kicks in extra juice from the batteries, until the generator can carry the load completely. - BFL13Explorer IIGordonThree, that is an interesting situation. The PM 100amper is PF corrected so it can run on a 15a circuit but I am not sure how much it actually draws in VA. It might well be too much for a 2000w generator. You can't set a 120v amp limit on it like you can with the charger portion of your inverter/charger either.
I am unclear as to how you get the generator to be on when one of these episodes happen. It is not like being on shore power. Anyway, there must be a way to get it all to work. - GordonThreeExplorer
BFL13 wrote:
GordonThree wrote:
BFL13 wrote:
GordonThree wrote:
LOL at the bong in one of the inverter pictures on fleabay
that powermax is interesting, could make my own hybrid inverter system without having to swap my Magnum for a Magnum Hybrid.
Not sure what is meant there. I have had a PowerMax 100amper and a 2000w inverter mounted together for four years now, but I have not used the charger to support the inverter.
I have done PT's trick when on 15a shore power, to put the MW, etc on the inverter and just plug the rig with its Parallax 7355 converter into the shore power. That keeps the big 120v things- only run occasionally- from popping any breakers while the converter gets the batteries back up afterwards in between when the big things are on.
BTW, since that older PM3 (which can be found at a lower price than that at times) PowerMax now has PM4s and Randy at bestconverters has his own version of those he calls Boondockers. There is also a manually adjustable voltage version.
That's pretty much it... instead of swapping my MS2812 for an MSH3012... I could add the powermax directly to the batteries, and power it directly from a yamaha 2000. this way the RV stays on the inverter, and I can run loads too big for the single yammy to handle. cyclic loads such as dehumidifier or air conditioner don't draw 15 amps continuously, so once the battery bank starts the load, the generator should be able to carry it.
Be aware that even an ordinary 55a converter acts differently when "backing up" the battery under load from a big inverter draw from how it does when charging a battery (with its increasing R and reduced voltage spread between charger and battery as the battery charges up to ever higher voltage).
My 13.8v single voltage 7355 does 56 amps constant when acting as a power supply to the batteries that are being drawn at 100a or whatever over 56a by the inverter ( I have improved the converter battery paths to a very low R)
So you don't need a 100a charger for that job unless you are short of generator time and not on shore power when running the big 120v loads on the inverter. Your "usually lame at battery charging" converter, will do quite well in that "back up" role instead. (If your wiring is low R)
I use the 100amper when the batts get down and I plug the trailer into the gen instead of the inverter so the rig is on converter for 12v. Then I plug the 100amper into the gen to recharge the disconnected batts so they have no load on them from the rig subtracting from the recharge amps and thus taking longer/ more gen time to do the recharge.
That's the only time I use the 100amper. It is not the rig's converter (It could be if the 7355 ever dies--no sign of that!)
I don't have a converter, threw that junk away when I installed my Magnum.
The hybrid Magnum's brain works differently. Instead of disconnecting the generator, it kicks in extra juice from the batteries, until the generator can carry the load completely. - MrWizardModeratori remember a cartoon
in fact i think the game of that name was invented because of his drawings - MEXICOWANDERERExplorerAll this makes a campfire look mighty tempting. I don't how many of ypu remember the Rube Goldberg cartoons...
I like techhie stuff but if I hear my neighbor start calling Igor that's over the top.
"Nice chainsaw you got there"
"Yeah, when the seventy-two inchers went on sale I couldn't resist. Looky here, the 2015 models got electric start" - BFL13Explorer II
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
