Yaj wrote:
Use some SeaFoam in your gas tank!
The stuff really does work. You can use a double dose and not hurt anything, just pour it in, run the generator long enough to get it worked through the system and then let it sit in the carb for a day or 2.
I have been amazed with the results I have had using it!
Good Luck!
Actually, in my previous post, I recommended against additives, but it will not hurt anything to try this first before you go to the expense of a rebuilding the carb. I've never used Seafoam, but if it works great.
