Bumpyroad wrote:
joe0508 wrote:
Ok i will try the seafoam but where can i get it at.I have also heard of a spray called sea foam deep creep that you can spray through the air cleaner housing into the carburator to clean it.Would this be something worth trying in addition to the seafoam in the gas tank?
sounds like a plan to me. I was going to recommend seafoam but didn't know about deep creep.
bumpy
Deep Creep is Sea foam with a spay nozzle. I use a spray nozzle in a regular can of Sea foam it is cheaper. You can also and it to your crankcase oil before you change it. You will be amazed at the carbon deposits that are removed when you drain the old oil.
