- Old-BiscuitExplorer IIIAS Scott suggested.....
Just drill a new hole and bot it back up.......DONE! - MrWizardModeratorif you can get it out of there
weld in a piece of angle iron from the hardware store, to cover the bad spot, then drill a hole
put it back using stainless nuts and bolts - ScottGNomadI would remove the rusted bolt and fabricate a rectangular "washer" to fill that area in and have it overlap a larger area of that flange. Then install a stainless bolt.
Or, simply drill another hole farther up and install a new bolt. - darsben1Explorerhave one fabricated where you are.
The closest I can find are
https://www.etrailer.com/enclosed-trailer-parts/stromberg-carlson/sm-01.html
