dougrainer
Aug 09, 2016Nomad
Carrier batteries last a LONG time. The issue is probably something in the remote is not going to sleep or there is a fault causing the remote to keep trying to stay on or activating. I have seen this type problem on Motorhome KEY FOBS for the entry doors. The 3 volt batteries would go dead in a few weeks and if you watched the FOB, you would see the red LED light occasionally flash but no signal was sent. That continued flashing eventually killed the 3 volt battery. Doug
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
