TechWriter
Apr 19, 2016Explorer
Homeless by Choice wrote:
Winegard returned my phone call and said that the ONLY Winegard product that would work with my 722K receiver is G2+ Carryout. I have to put a "power inserter" which comes with their system in the coax line, supply 120vac to it until it finds the satellite (and then I can unplug it) and the 722K should receive all my DISH HD channels.
Kind of.
From the G2+ Manual . . .
Q.
Does the Carryout G2+ antenna work with a DVR?
A:
Yes, the Carryout G2+ antenna can be set up to work with most DVR receivers. Two coaxial cables will need to run from the Carryout G2+ antenna to the DVR, and the receiver will only be able to watch or record from one satellite at a time, which may limit some DVR functionality. The Carryout G2+ antenna is not compatible with the Hopper/Joey for DISH. The Carryout G2+ antenna is not compatible with H25, HR34, or HR44 for DIRECTV (unless the SWM-840 accessory kit is added).
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
